Displays the wide ACL mode configured on the supported switch or slot.
| slotNo | Specifies the slot to display. |
| all | Specifies all slots. |
N/A.
Use this feature to display the width of the ACL TCAM key configured on a switch as being double wide or single wide.
The following command displays the wide key mode on all slots:
show access-list width slot all
Following is sample output for this command:
Slot Type Width (Configured) ---- ---------------- --------------------- 1 X460G2-48t-10G4 Single 2 X460G2-48t-10G4 Single 3 X670G2-48x-4q Double 4 Single 5 Single 6 Single 7 Single 8 Single double
This command was first available in ExtremeXOS 12.5.
